045083: All voxel values are null.
A null value was predicted for every location in the output netCDF file.
Solution
Verify that at least one input point has a valid value and is between the minimum and maximum elevation clipping rasters.
If this error is encountered using the IDW 3D tool, verify that the search neighborhood uses at least one neighbor per sector.
If this error is encountered using the GA Layer 3D To NetCDF tool, verify that the input geostatistical layers contain nonnull predictions within the output extent.
