050240: The same height surface cannot be used for both the Minimum Height and Maximum Height parameters.
The same height source was provided for the minimum height surface and maximum height surface parameters of the Extract Objects From Point Cloud tool. No output can be generated when using the same surface for these parameters.
Solution
Ensure that different surfaces are used to define the minimum height surface and maximum height surface parameters.
