110028: This tool requires at least 30 bins in the Space Time Cube.
You have provided an Input Space Time Cube where less than 30 bins have nonzero point counts.
Solution
The tools in the Space Time Pattern Mining toolbox are designed to work with larger datasets. If your cube has counts for several hundred points, it may make sense to re-create the space-time cube (use the Create Space Time Cube tool) with smaller bin dimensions.
