110039: <value> input features were located outside the processing extent.
Some of the Input Features fall outside of the Template Cube or Polygon Analysis Mask. These point features will not be included in the analysis.
Solution
If you are using a Template Cube and want all of the Input Features to be included in the analysis, you will need to re-create the template cube using the Create Space Time Cube tool. If you are using a Polygon Analysis Mask and want all of the Input Features to be included in the analysis, you will need to extend the polygons to include all of the points or not use a Polygon Analysis Mask for the analysis.
