110041: The processing extent environment setting is ignored in favor of the template cube extent.
When you provide a Template Cube, its extent sets the processing extent even when you have set the processing extent environment.
Solution
If the processing extent for the Template Cube is not correct, you can re-create it using the Create Space Time Cube tool.
