110054: If some or all of your data is not drawing, it may fall outside of the Visibility Range limits, which can be cleared. If some or all of your data is underground, you may need to turn off Elevation Surfaces.
Visibility Range limits are set automatically to increase processing speed and can then be cleared. Because time is used as the vertical axis in visualizing the space-time cube, it is important for accurate interpretation that all locations on the ground are at the same elevation. Elevation services can be turned back on when you are done with your analysis.
Solution
For more information about how to clear Visibility Range limits and turn off Elevation Services, see Visualize the space-time cube.
