110538: The Time Span Per Cluster chart was not created because there are more than 10,000 records.
The Time Span Per Cluster line chart cannot be created if there are more than 10,000 records in the output.
Solution
This is an informational message. No action is required.
To see the line chart for a particular cluster that has 10,000 or fewer records, select and copy all records of the cluster to a new dataset. You can then create a line chart using the input date field and cluster ID values.
