110635: It is recommended to not use an Object ID field as the unique ID field.
Because system-managed ID fields such as OID, FID, and OBJECTID can be reordered (for example, when using the Sort tool), it is recommended that you not provide them in the Unique ID Field parameter.
Solution
No action is required; however, you can use the Calculate Field tool to make a copy of the object ID field and use the copy as the unique ID field.
