110647: The aggregation boundary contains more than <value> vertices, which may significantly slow processing time. Consider simplifying or generalizing the custom polygons.
The provided aggregation boundary polygon contains many vertices. This can cause long execution times for the tool.
Solution
No action is required. However, consider using the Simplify Polygon tool to reduce the number of vertices of the aggregation boundary polygon.
