120167: Bin generation and analysis requires a projection coordinate system. The <value> projection has been applied with custom projection parameters based on the analysis extent.
Creating bins of squares or hexagons requires a projected coordinate system. Since a projected coordinate system was not provided, analysis will be completed using the best estimate. The estimate is based on the extent of the input data and the analysis type, which is binning.
Solution
This is an informative message. To specify a different projected coordinate system, set the output coordinate system in the Environment Settings.
