120279: Connection file path <value> is not valid.
The multifile feature connection file (.mfc) you specified contains invalid JSON.
Solution
Verify that you have correctly specified a pathway to the multifile feature connection file (.mfc). A pathway to a .mfc file should be formatted such as c:\MyProjectFolder\MyMultifileFeatureConnection.mfc.
If you suspect you have made invalid manual edits to your multifile feature connection, try re-creating the connection using the Create Multifile Feature Connection tool.
To learn more about .mfc files and formatting, see Multifile feature connections.
