130126: The vertical coordinate systems of <value> and <value> datasets do not match.
The vertical coordinate systems of the input and target datasets do not match.
Solution
Use the Project tool to transform your source data into a dataset that matches the target LRS Network's vertical coordinate system, or use the Define Projection tool to set your existing source or target dataset to the correct vertical coordinate system.
