180302: No elevator delay applied as <value> field was not found in thinned pathways.
The specified field was not found in the thinned pathways layer so no elevator delay was applied.
Solution
The tool uses the specified field's values to calculate more accurate travel times for routes that use elevators. Elevator delays can be applied using the Generate Floor Transitions tool.
