180306: Unit attribute values are null.
The tool encountered an error while populating transition features with required Unit attribute field values.
Solution
This error is usually data specific. Completing one of the following may resolve the issue:
  • Use the Create Indoor Dataset and Create Indoor Network Dataset tools to create an empty indoor dataset and indoor network dataset. Then append features from the existing Units feature class into the new Units feature class
  • Use the Create Indoors Database tool to create an empty Indoors geodatabase. Then append features from the existing Units feature class into the new Units feature class.
Contact Esri technical support for more information.
