180483: Failed to create attribute rules for target dataset.
Attribute rules could not be created for the feature class, possibly due to one of the following:
Editor tracking could not be enabled on the feature class.
Global IDs could not be added to the feature class.
Branch versioning has not been enabled if using an enterprise geodatabase.
Solution
Do one of the following:
Enable editor tracking manually on the feature class using the Manage tab. Then add attribute rules to the feature class.
Run the Add Global IDs tool to generate global IDs for the feature class.
Register the geodatabase as branch versioned if you're using an enterprise geodatabase.
