Create attribute rules
Available with the ArcGIS Indoors Pro or ArcGIS Indoors Maps extension.
Creating and maintaining accurate floor plan data is important when building floor-aware maps and using them in apps. One method of quality control in ArcGIS Pro is implementing attribute rules in the database. When you create an indoor dataset using the Create Indoor Dataset or Create Indoors Database tool, you can add a collection of attribute rules to floor plan feature classes. After adding floor plans to the indoor dataset, you can run these validation rules to check the data for common and critical data issues, such as unique IDs, floor-aware relationships, and spatial integrity.
You can run the Upgrade Indoors Database tool to add any missing Indoors attribute rules or overwrite existing rules with the latest version.
You can run validation attribute rules on data in a file geodatabase or in a branch-versioned feature service. Each method uses a slightly different workflow.
When attribute rules are added to an Indoors workspace using the Create Indoor Dataset, Create Indoors Database, or Upgrade Indoor Database tool, the following occurs:
A global ID field is created in the feature classes in the indoor dataset.
Editor tracking fields are created in the feature classes in the indoor dataset and editor tracking is enabled.
A validation field is created in the feature classes in the indoor dataset. This field is managed by the Error Inspector tool and is used to determine whether attribute rules have been run on a feature since its most recent update.
Four error datasets are added to the geodatabase as stand-alone layers. These feature classes correspond to point, polyline, polygon, and table errors and are managed by the Error Inspector. A
LEVEL_IDfield is added by the Create Indoor Dataset, Create Indoors Database, and Upgrade Indoors Database tools to enable visualization of data errors using the floor filters. When you add the error layers to a map and open the Error Inspector, they are automatically configured as floor aware.Note:
Error datasets are created when the first validation attribute rule is added to the geodatabase. If error datasets already exist in the database, or you import the attribute rules into an existing Indoors workspace, you can manually add a
LEVEL_IDfield to the datasets.A series of validation and calculation rules are applied to the following feature classes: Sites, Facilities, Levels, Units, and Details. Validation rules are run when you specify to check for issues in the data. The included calculation rules are used to manage the Validation field, which determines whether the validation checks are run on a feature.
You can add the attribute rules to the geodatabase manually at a later time if you create the Indoors workspace without them.
You can edit existing attribute rules or create rules to meet your organizational requirements. You can manage rules, including editing the Arcade script, and enabling, disabling, deleting, or adding new rules from the Attribute Rules view.
Caution:
If you change the name of the feature classes in the geodatabase, you must also edit the names in the Arcade scripts.
Validation checks
The following validation rules are created in the Indoors dataset:
Details
Rule name |
Rule type |
Description |
Unique ID |
Validation |
This rule checks that the Update each nonunique Detail ID so that it is unique in the feature class. |
Detail Level Information |
Validation |
This rule checks that the Update the |
Levels
Rule name |
Rule type |
Description |
Unique ID |
Validation |
This rule checks that the Update each nonunique level ID so that it is unique in the feature class. |
Valid Facility ID |
Validation |
Missing unit(s) |
Validation |
This rule checks each level for the following:
Review the units on levels with errors to determine whether there are missing unit features or units that exist outside the level boundary when they shouldn't. |
Facilities
Rule name |
Rule type |
Description |
Unique ID |
Validation |
This rule checks that the Update each nonunique facility ID so that it is unique in the feature class. |
Valid Site ID |
Validation |
Sites
Rule name |
Rule type |
Description |
Unique ID |
Validation |
This rule checks that the Update each nonunique site ID so that it is unique in the feature class. |
Units
Rule name |
Rule type |
Description |
Unique ID |
Validation |
This rule checks that the Note:You cannot import occupant data using the Update Occupant Features tool if any unit IDs are not unique. Update each nonunique unit ID so that it is unique in the feature class. |
Unit Level Information |
Validation |
Overlapping geometry |
Validation |
This rule checks that a unit does not overlap another unit located on the same level. Update unit geometries so they do not overlap. |
Unit contains another unit |
Validation |
This rule checks that a unit is not fully contained in another unit. This can include the following scenarios:
Create validation attribute rules
To create validation attribute rules in an Indoors workspace, complete the following steps:
Open an Indoors workspace in ArcGIS Pro.
If the Indoors workspace is an enterprise geodatabase, enable branch versioning.
Learn more about branch versioning
In the Catalog pane, right-click the enterprise geodatabase connection, and click Geodatabase Connection Properties.
The Geodatabase Connection Properties dialog box appears.
For Versioning Type, choose the Branch option.
Click OK.
Run the Create Indoors Database or Create Indoor Dataset tool with the Create Attribute Rules check box checked.
Once you add attribute rules, you can run the validation checks to identify errors in the floor plan data.
Add attribute rules to an existing Indoors workspace
To add attribute rules to feature classes in an existing indoor dataset, complete the following steps:
Add global IDs to an indoor dataset.
Enable editor tracking on the indoor dataset.
Click OK.
Run the Import Attribute Rules tool to add the attribute rules to each feature class.
Attribute rules are stored as
.csvfiles in the ArcGIS Pro installation at<Installation location>\Resources\AttributeRules\Indoors\en-US\<Feature class name>.csv.
