180612: The table was not found: <value>. Unable to run attribute rule: <value>.
A target dataset has an attribute rule that references a table that does not exist in the target dataset. This can occur when a feature class name is changed after the creation of an attribute rule that references the feature class.
Solution
Modify the attribute rule's expression to refer to the new feature class name. This will require an exclusive lock on the target dataset. Alternatively, you can disable or delete the attribute rule.
