180713: Field: <value> in the <value> table is expected to be <value> type, will not be upgraded.
The specified field in a table in the indoor dataset is expected to be the specified field type based on the latest Indoors model.
Solution
Do one of the following:
  • Change the specified field's type to conform to the latest Indoors model schema.
  • Rename the table and run the Upgrade Indoors Database tool again to create the table with the expected field types. Append data from the original table to the new table.
  • Rename the field and run the Upgrade Indoors Database tool again to create the field with the expected data type. Use the Calculate Field tool to populate the new field with values from the original field.
