180837: Error generating floor plan from point cloud.
An error occurred when creating floor plan polylines using the input point cloud data.
Solution
This error has more than one possible cause, including missing or sparse data.
Try the following:
  • Verify that the point cloud, map, and the Extent parameter (if specified) all use the same coordinate system.
    ArcGIS Pro does not reproject LAS data on the fly. If required, use the Extract LAS or Project LAS tools to project LAS data to a different horizontal coordinate system.
  • Use the Extent parameter to limit processing to a dense portion of the point cloud.
  • Increase the width of any specified range for the Z Ranges parameter by 0.2 meters (0.5 feet).
  • Verify that the input point cloud has no filters applied that exclude data from processing.
If the issue persists, contact Esri Technical Support for further assistance.
