240022: The existing public transit data model tables include the LVEShapes feature class, but the option to make LVEShapes from the shapes.txt file is set to False. LVEShapes features will not be created for the appended data.
You have chosen to append data into an existing set of public transit data model feature classes and tables. The existing data has the optional LVEShapes feature class, but you have not chosen to output LVEShapes using the GTFS shapes.txt file for the data you are appending. Consequently, no additional rows for the appended data will be added to the existing LVEShapes feature class.
Solution
Turn on the option to generate LVEShapes output from the shapes.txt file.
If you don't need the LVEShapes feature class or plan to update it using a different process, ignore the warning.
