260004: The tool you are running requires more memory to compute the result.
The tool you are running doesn't have enough memory available.
Solution
If possible, increase the amount of memory available on your machine and verify that you set the Parallel Processing Factor environment high enough.
If you cannot modify the memory, refer to the tool help to see if there are parameter changes you can make. The following are examples:
Use a smaller batch size when possible.
Use a subset of the data.
