Generate Excel From Geodatabase (Topographic Production Tools)
Summary
Creates a Microsoft Excel file (.xls or .xlsx) from the contents of a geodatabase.
Usage
  • This tool will create an Excel spreadsheet that defines the schema of a topographic production database and can be used in the Generate Geodatabase From Excel tool.
  • The Excel file that is generated consists of multiple worksheets based on the components of the geodatabase. The individual worksheets in the file contain the spatial reference, datasets, object classes, subtypes, fields, domains, and metadata to be included in the geodatabase.
Parameters
Label Explanation Data type
Input Geodatabase
The geodatabase that will be used to create the Excel spreadsheet.
Workspace
Output Excel File
The Excel file that will be created from the geodatabase.
File
Environments
This tool does not use any geoprocessing environments.
Licensing information
  • Basic: No
  • Standard: Requires Topographic Mapping
  • Advanced: Requires Topographic Mapping
