Convert Geometric Network To Trace Network (Trace Network Tools)
Summary
Converts a geometric network to a trace network.
Usage
When working with a file geodatabase, the input geodatabase workspace must be an ArcGIS 10.0 or later release to support this functionality.
When working with an enterprise geodatabase, the following are requirements:
The geodatabase version must be 10.8.1.2.6 or later.
The ArcGIS Enterprise version must be 10.9 or later. The ArcGIS Pro and ArcGIS Enterprise versions determine the trace network version that is created. For more information, see Trace network compatibility.
The Input Geometric Network parameter value must be from a database connection established as a database-authenticated user and owner of the input feature dataset and geometric network. This user must have database privileges to create content and cannot be an OS-authenticated user, a database administrator, or the geodatabase administrator account.
- This database-authenticated user will become the database trace network owner when the geometric network is converted to a trace network.
License:
Organization members must be assigned a license for the ArcGIS Advanced Editing user type extension to create, publish, and edit a trace network in an enterprise geodatabase. Query and trace operations do not require this user type extension.
- The active ArcGIS Enterprise portal account is recorded in the network properties as the portal trace network owner when the geometric network is converted to a trace network.
Parameters
| Label | Explanation | Data type |
Input Geometric Network |
The geometric network that will be converted to a trace network. Caution:Converting a geometric network to a trace network will drop the geometric network and create a trace network in its place. This change cannot be undone. Create a backup of the data before proceeding. |
Geometric Network |
Output Trace Network Name |
The name of the output trace network. |
String |
Derived output
Output Trace Network |
The output trace network. |
Trace Network |
Environments
This tool does not use any geoprocessing environments.
Licensing information
- Basic: No
- Standard: Yes
- Advanced: Yes
