Import Trace Configurations (Trace Network Tools)
Summary
Imports named trace configurations from JSON format (.json file) to a trace network.
This tool can be used in conjunction with the Export Trace Configurations tool.
Usage
The input trace network must be version 2 or later.
The following requirements must be met when working with an enterprise geodatabase:
- The Input Trace Network parameter value must be from a trace network service.
- The Input Trace Network parameter value can be from a database connection established as the database trace network owner when connected as the portal trace network owner or a portal account with the administrator role.
The named trace configurations must be in a single
.jsonfile.The information in the
.jsonfile is stored in the following format:[ { "creator": "<property representing the connected portal account on creation>", "name": "<property representing the name of the named trace configuration>", "description": "<property representing the description of the named trace configuration>", "traceType": <property representing the trace type>, "configuration": <property representing the collection of trace configuration parameters>, "resultTypes": "[<property representing the types of results to return>]", "tags": "<property representing user provided tags>" } ]Example JSON to import named trace configurations into a trace network using the Import Trace Configurations tool:
[ { "creator": "TN_Admin", "name": "Connected trace HUC12", "description": "Connected trace for HUC12", "traceType": 1, "configuration": {"{"includeBarriers":true,"validateConsistency":true,"ignoreBarriersAtStartingPoints":true,"allowIndeterminateFlow":true, "traversabilityScope":"junctionsAndEdges","combineUsingOr":false,"isSpecificValue":true}],"functionBarriers":[], "functions":[],"outputFilters":[],"outputConditions":[],}",}, "resultTypes": "[{"type":"elements","includeGeometry":false,"includePropagatedValues":false,"networkAttributeNames":[],"diagramTemplateName":"","resultTypeFields":[]},{"type":"aggregatedGeometry","includeGeometry":false,"includePropagatedValues":false,"networkAttributeNames":[],"diagramTemplateName":"","resultTypeFields":[]}]", "tags": "connected,nhd,huc12" } ]
Parameters
| Label | Explanation | Data type |
Input Trace Network |
The target trace network to which the named trace configurations will be imported. |
Trace Network; Trace Network Layer |
Input File (.json) |
The |
File |
Derived output
Updated Trace Network |
The updated trace network. |
Trace Network |
Environments
This tool does not use any geoprocessing environments.
Licensing information
- Basic: No
- Standard: Yes
- Advanced: Yes
