Set Flow Direction (Trace Network Tools)
Summary
Sets the flow direction of line features in a version 1 trace network.
Usage
  • Flow direction can only be set with Set Flow Direction tool for line features that participate in a version 1 trace network.
    Legacy:
    The Set Flow Direction tool is not supported with Trace Network Version 2 or later. Use the FLOWDIRECTION network attribute field to set or modify the flow direction of a line feature in the network.
  • The network topology must be enabled.
  • Flow direction can be specified at the feature level with digitized direction, against digitized direction, or as indeterminate. When a selection of features exists on the map, the flow direction will be set for only those features.
    Learn more about how to set flow direction
Parameters
Label Explanation Data type
Input Trace Network
The trace network that contains the line feature class on which the flow direction will be set.
This parameter requires a Trace Network Version 1 as input.
Trace Network; Trace Network Layer
Feature Layers
The polyline features that participate in the input trace network.
Feature Layer
Flow Direction
Specifies the flow direction of the edges.
  • With digitized direction—Flow direction will be along the digitized direction of the edges.
  • Against digitized direction—Flow direction will be against the digitized direction of the edges.
  • Indeterminate direction—Flow direction will be indeterminate.
String
Derived output
Updated Trace Network
The updated trace network.
Trace Network
Environments
This tool does not use any geoprocessing environments.
Licensing information
  • Basic: No
  • Standard: Yes
  • Advanced: Yes
