Set Network Attribute (Trace Network Tools)
Summary
Assigns a network attribute to a feature class to be used during trace operations.
A trace network can include network attribute. A network attribute is a value stored in the network topology derived from attributes on corresponding features in the network. While a network attribute can be associated with only one attribute in a feature class, there is no limit to the number of network attributes a trace network can include. Network attributes are used as weights to control traversability and to model the cost of paths in the network.
Usage
Network attributes are used in trace analyses to control how the network can be traversed.
A network attribute can be associated with only one attribute in a feature class but can be assigned to multiple feature classes in the network.
The network topology must be disabled.
This tool can be used in conjunction with the Add Network Attribute tool, which adds a network attribute to the trace network.
When working with an enterprise geodatabase, the requirements are as follows:
The input trace network must be from a database connection established as the database trace network owner.
License:
Organization members must be assigned a license for the ArcGIS Advanced Editing user type extension to create, publish, and edit a trace network in an enterprise geodatabase. Query and trace operations do not require this user type extension.
This tool must be executed when connected to the default version.
Parameters
| Label | Explanation | Data type |
Input Trace Network |
The trace network that contains the network attribute to set. |
Trace Network; Trace Network Layer |
Network Attribute |
The network attribute to be assigned to the feature class field. |
String |
Feature Class |
The input feature class that contains the field that will be used to set the network attribute. |
String |
Field |
An existing field that will be assigned the network attribute. The field data type must match the data type of the network attribute. For example, if the network attribute is a short integer type, the field must also be a short integer type. Network attributes that do not support null values can only be assigned to fields that do not allow null values. |
String |
Derived output
Updated Trace Network |
The updated trace network. |
Trace Network |
Environments
This tool does not use any geoprocessing environments.
Licensing information
- Basic: No
- Standard: Yes
- Advanced: Yes
