Delete Trace Configuration (Utility Network Tools)
Summary
Deletes one or more named trace configurations from a utility network.
Usage
Using this tool, named trace configurations are permanently deleted from the utility network.
When working with an enterprise geodatabase, the input utility network must be from a utility network service.
When working with an enterprise geodatabase, the connected portal account can only view and delete named trace configurations they create. The portal utility network owner can view and delete any named trace configurations in the utility network.
License:
The active portal account must be assigned a license with the ArcGIS Advanced Editing user type extension to use this tool in an enterprise deployment.
Parameters
| Label | Explanation | Data type |
Input Utility Network |
The utility network containing the named trace configuration to be deleted. |
Utility Network; Utility Network Layer |
Trace Configuration |
The named trace configurations to be deleted. |
String |
Derived output
Updated Utility Network |
The updated utility network. |
Utility Network |
Environments
This tool does not use any geoprocessing environments.
Licensing information
- Basic: No
- Standard: Yes
- Advanced: Yes
