Essential vocabulary
The following terms are used in ArcGIS for SharePoint. For more Esri and GIS terminology, see the Esri GIS Dictionary.
ArcGIS
The brand name for Esri GIS products. ArcGIS provides an online infrastructure for making maps and geographic information available throughout an organization, across a community, and on the web. By signing in to your ArcGIS organization, you can access ready-to-use maps and apps or create maps that tell a story. With ArcGIS for SharePoint, you can combine your business data with data from ArcGIS to create detailed maps that help you analyze the data visually and make better decisions. ArcGIS also allows you to share maps and map layers within your organization or with colleagues in the field.
ArcGIS for Microsoft map
The ArcGIS for Microsoft map is the name of the map view and set of tools that you can use in ArcGIS for SharePoint. When signed in to ArcGIS, the map allows you to access ArcGIS content and data and to integrate with your Microsoft data.
Areas
Enclosed polygons that represent the shape and location of homogeneous features such as states, counties, parcels, and land-use zones.
Attributes
Fields and values for a single feature or nonspatial record. Attributes are typically stored in a database or service, such as a feature service. They are used to classify and filter data in data-driven visualizations.
Basemap
A layer that provides a geographical context, or background, for the content you want to display in a map. With ArcGIS for SharePoint, you can choose from several basemaps hosted on ArcGIS. These include options that combine road, aerial, and topographic data with a variety of symbology. If your organization makes them available, you can also sign in to access basemaps from your ArcGIS organization.
Clustering
The function of organizing point features that are within a certain distance of each other into a single symbol to view and understand a map containing many data points. This is different from grouping in which features are grouped by a user-specified category and styled accordingly.
Coordinate system
A reference framework that consists of points, lines, or surfaces, and a set of rules used to define real-world locations.
In ArcGIS for SharePoint, you can choose between World Geodetic Survey 1984 (WGS84), Web Mercator, and several other supported coordinate systems. You can also import a custom coordinate system from a map or feature service hosted on ArcGIS.
A geographic coordinate system is used to find locations on a globe or sphere. WGS84 is a common geographic coordinate system in which every location on the earth is specified by a set of numbers (coordinates). Coordinates are often expressed as latitude and longitude values.
A projected coordinate system is used to translate locations on a globe to locations on a flat surface, such as a monitor or paper map. Web Mercator is a common projected coordinate system in which locations are identified by x,y coordinates on a grid, with the origin at the center of the grid. Coordinate values in the Web Mercator system generally have six, seven, or eight digits to the left of the decimal, and the units are meters. If you are unsure which coordinate system to use, contact the originator of the data or the person who collected it.
Coordinates
Coordinates are used to represent locations in space relative to other locations. Coordinates are often shown in latitude-longitude pairs in which x-coordinates range from -180 to 180 and y-coordinates range from -90 to 90, or as values with six, seven, or eight digits to the left of the decimal point. When using ArcGIS for SharePoint, these value pairs are often composed of the values from two columns in the data.
Feature
The term geographic feature is typically shortened to feature in ArcGIS for SharePoint. Geographic features are representations of things located on or near the surface of the earth. Geographic features can occur naturally (such as rivers and vegetation), can be construction items (such as roads, pipelines, wells, and buildings), and can be subdivisions of land (such as cities, boundaries, or land parcels). Geographic features are most commonly represented on a map as points, lines, or polygons. In ArcGIS for SharePoint, data you add to a map is represented as geographic features.
Feature service
A data hosting endpoint that provides access to a collection of geographic features. Each feature in a feature collection has a spatial location, a set of properties, map symbology, and pop-up information. You can search for feature services in ArcGIS and add them to a map. When you add a feature service to a map, it becomes one or more layers in the map.
Grouping
The process of placing features in user-specified categories and styling them accordingly.
Guest user
An ArcGIS for SharePoint account type that is included with a Microsoft license. A licensed ArcGIS for SharePoint user that is not signed in to an ArcGIS account can access ArcGIS for SharePoint, provided that it has been properly installed and configured by the site administrator or by a licensed user.
This account type has limited functionality. See the Accounts topic for an overview of the limitations to guest users.
Heat map
A map that shows the relative geographic distribution of point density using a continuous color ramp that implies temperature ranging from cool (few points) to hot (many points).
Layer
A method of visually representing geographic data. A map can contain multiple layers, and each layer is rendered as one legend item on that map. On a road map, for example, roads, national parks, political boundaries, and rivers can each be considered unique, separate layers. When you add data to a map, ArcGIS for SharePoint creates a layer for that data and includes it in the Layers list. Once the layer is created, editable functionality such as layer visibility, style configurations, and transparency is enabled.
Lines
Also known as polylines. A type of feature geometry containing ordered point coordinates and a spatial reference. Each point on a line can be expressed as an x,y coordinate, with an optional z-value for elevation and m-value for linear referencing.
Map
A collection of layers that displays geographic data and is used to explore and interact with that data. You can add ArcGIS for SharePoint data directly to a map and combine it with content from ArcGIS.
Map service
A data hosting endpoint that provides prestyled collections of map cartography organized by location and scale. You can search for map services on ArcGIS and add their contents to a map. When you add map service content to a map, it becomes one or more layers in the map.
Pan
The function of shifting a map extent relative to the display window without changing the viewing scale. Panning can also be thought of as moving the map image across the display window to view different parts of the map.
Points
A type of geometry that represents discrete locations of geographic features, such as well locations, telephone poles, and stream gauges. They contain a single set of x,y coordinates and a spatial reference and are often expressed in longitude (x) and latitude (y) values. They can also have an optional z-value for elevation and an m-value for linear referencing. Points can also represent address locations, GPS coordinates, or mountain peaks.
Polygons
Geometric enclosed areas (many-sided figures) that represent the shape and location of features such as states, counties, parcels, and land-use zones. Polygons are often called areas. Each polygon is composed of a series of x,y coordinates, or points, and a spatial reference, as well as an optional z-value that defines each x,y coordinate's elevation, and an optional m-value for linear referencing. These define the precise location (latitude and longitude) of the polygon's boundary.
Web map
A digital map file that contains a map's layers, styles, and related data. You can search for a web map on ArcGIS and add it to a map. When a web map is added to a map, the individual layers in the web map become layers in the map.
