Add a slide background
The briefing slide background is set to the background color from the current theme, but you can override this and apply the following styles:
  • Solid color
  • Gradient
  • Image
Use the following steps to add a slide background:
  1. Click the Slide actions button on the top edge of the slide.
  2. Click Change background.
  3. Choose a Background style option.
    1. For Color, choose a color by clicking a swatch or setting a custom color.
    2. For Gradient, choose a gradient option.
    3. For Image, click Add image and upload a background image.
  • Only one background style can be applied at a time.
  • A background set on a slide will persist if the theme is changed.
  • You may have to adjust text colors on the slide if you choose a color or gradient that is very different than the original theme background color.
  • When using an image, use a 16:9 image with background elements that do not conflict with areas where you plan to add text.
