AI in ArcGIS Survey123
ArcGIS Survey123 uses artificial intelligence (AI) in a variety of ways throughout the software.
For more information about each generative AI capability, see the following:
Capability |
Supported app |
Learn more |
Use a conversation to help design a survey |
Survey123 web designer |
Translate survey designs |
Survey123 web designer* |
Image analysis, text analysis |
Authored in the Survey123 web designer or Survey123 Studio, for use in the Survey123 web app or Survey123 Mobile |
Analysis calculations in the Survey123 web designer or Survey123 Studio |
Audio transcription (beta) |
Before you can access AI in Survey123, the following requirements must be met:
Your organization administrator must configure AI to allow members to use AI features in ArcGIS. The administrator must also enable AI assistants, AI premium services, or both.
For beta features, your organization administrator must turn off the Block Esri apps and capabilities while they are in beta.
You must also have privileges to use AI assistants, AI premium services, or both. The following lists which capabilities are enabled by each privilege:
AI assistants—Use a conversation to help design a survey, translate survey designs.
AI premium services—Image analysis, text analysis, audio transcription (beta).
Image questions in surveys published with Survey123 Connect can also be configured to perform image classification, object detection, and object redaction in the Survey123 field app. These capabilities rely on machine learning models that are located on the device, do not use online generative AI services, and are not configured by your ArcGIS Online administrator. For more information, see Smart assistants.
Credits
Using a conversation to help you design a survey and the translation assistant do not consume credits. AI image and text extraction consume credits. For more information, see Understand credits in the ArcGIS Online documentation.
Feedback
To provide feedback about an AI response, click the Positive feedback
or Negative feedback
button to open a survey and enter your feedback. When you submit a survey, your feedback may be used to guide future development of Esri products and documentation.
Security and privacy
AI in Survey123 aligns with the following principles:
Prompts are not used to train Esri or third-party AI models.
Prompts are not used to improve any Esri or third-party product or service.
Prompts are not stored or shared unless you give explicit permission, such as when you provide feedback about the assistant.
Prompts are not used to improve the assistant for your own use.
AI transparency cards are available with more security and privacy details.
Limitations
The following are limitations when using AI in Survey123:
An ArcGIS Online organizational account is required to access AI in Survey123. Other account types, such as public accounts, are not currently supported.
Suggestions generated using AI can be misleading or inaccurate. To avoid potentially reinforcing any unintentional biases in the AI models used by Survey123, human judgement should be applied to interpreting and acting on the assistant's outputs.
At its discretion, Esri may implement a rate limit on AI use to maintain performance.
Resources
Use the following resources to learn more:
