Run the export queue
Available with an ArcGIS Topographic Mapping license.
Once you add AOIs to the export queue, you can begin exporting them, track their progress, and download completed exports.
Click Export in the Export Queue pane to export the checked items in the queue.
The export is started and items are removed from the queue as they are exported.
Click the Export tab.
The Map Exports Status and Export Details panes appear. The Map Exports Status pane lists all of the exports.
Tip:
You can filter the list to show completed, in progress, failed, or canceled exports.
The following table describes the map export status types:
Status
Completed
The map export is complete.
In Progress
The map is actively exporting. The status bar reflects the progress of the export. Hover over it to check the progress.
Failed
The map export failed.
Canceled
The map export was canceled.
Click Filter Jobs
to filter the list by a date range.The date range filter and Sort By options appear.
Tip:
To change the field that is used to sort the list, click the Sort By drop-down arrow and choose one of the following options:
Name
Submission Date
Status
Map Type
User
Progress
Click Apply to apply the changes and return to the Map Exports Status pane.
Click Sort by
to sort the list.Click Refresh status
to refresh the status of each item in the list.Active exports automatically refresh every 30 seconds unless export settings have been configured to limit service requests.
Click an item in the Map Exports Status pane to review details in the Export Details pane.
This also highlights the AOI on the map.
Tip:
The following message options are available in the Export Details pane:
—Show informative messages.
—Show warnings.
—Show errors.
—Refresh messages.
—Display messages on a dialog box.
Click Download output file
next to a completed export job to download it.To cancel an export job that has been submitted or is in progress, click Cancel
on the job. Click Delete
next to a job that has been canceled or completed to delete it.Tip:
You can cancel, delete, or download multiple jobs at once by selecting more than one job. Press the Shift key while clicking another job to select a range, or press the Ctrl key while clicking jobs to select multiple jobs. Once jobs are selected, use the toolbar in the Map Exports Status pane to perform actions on all the jobs selected.
The number of jobs, as well as the number of jobs selected, are reflected at the top of the pane.
When you download a completed export, the save options appear. These options vary depending on your browser's settings.
