System requirements
Available with an ArcGIS Topographic Mapping license.
The self-serve Map Production System (MPS) web app uses ArcGIS Server configured with an ArcGIS Enterprise deployment. The product data files are also required to configure and deploy the app.
Prerequisites
The following components are required to deploy the MPS web app:
  • Enterprise 12.0 or later.
    • ArcGIS Server
    • Portal for ArcGIS
    • ArcGIS Web Adaptor
    • ArcGIS Data Store
  • Enterprise Topographic Mapping product data files installed on the server.
    • The product data file installation contains Topographic Production System (TPS) files and folders that must be copied from <Product files installation location>\ArcGIS Topographic Mapping\Product Files\<Enterprise version>\Applications\TPS\ to the <Enterprise installation location>\ArcGIS\Portal\apps\tps folder on your server machine.
    • The product data file installation contains Topographic Production System (TPS) files and folders that must be copied from <Product files installation location>/topographicmapping/productfiles/Applications/TPS/ to the <Enterprise installation location>/portal/apps/tps folder on your server machine.
    Important:
    Ensure you copy all of the contents from the product files TPS folder to the tps folder on your server machine.
  • The Topographic Production Service is deployed with the topographic production capabilities enabled. This is published from ArcGIS Pro.
  • ArcGIS Workflow Manager—If you are publishing this service to use Topographic Production workflows that integrate with ArcGIS Workflow Manager, a workflow item in Workflow Manager must be created so that you can provide its ID to the service.
  • The Topographic Production System app gallery must be enabled on the organization's portal properties. You can use the ArcGIS Portal Directory (Sharing API) to insert "tpsEnabled":true in the Portal Configuration Properties parameter.
Ensure that the fonts required by the map products you want to export are installed on your system.
Supported browsers
The MPS web app uses browser local storage, similar to browser cookies. If this storage is not available, the MPS app will not function properly. For the best performance, use the latest version of one of the following browsers:
  • Google Chrome
  • Microsoft Edge
Important:
Microsoft Internet Explorer 11, Microsoft Edge Legacy, Firefox, and Safari are not supported.
