Create a task group
Available with an ArcGIS Topographic Mapping license.
Once the Topographic Production Manager web app contains a project with a phase, a task group must be associated with the phase before you can use the app to manage work. To do that you must create a task group first.
The following steps guide you through creating a task group:
Click the Design tab at the top if it's not already the active view.
Click the Task Groups tab on the side.
The TaskGroups pane appears with available service items.
Tip:
Hover over the information icon to see the service URL.
Click Create a new task group
.The task group properties appear.
Provide a name for the task group in the Name text box.
Provide a description of the task group in the Description text box.
Click the Product drop-down arrow and choose a workflow product definition.
Check the check boxes for the days of the week that the work will be performed.
Specify the number of hours each day that the work will be performed.
Click SAVE.
The task group is created and listed under the corresponding service item in the TaskGroups pane.
Click Create new task group
to add another task group, or update an existing task group's settings by selecting it from the list and providing new values for the task group's properties.
When updating a task group's settings, the Create Taskgroup tab becomes the Update Taskgroup tab.
