System requirements
There are two types of system requirements: operating system requirements and user system requirements.
The operating system requirements describe the requirements the server infrastructure must fulfill for installing Urban. Ensure these requirements are met before starting to install ArcGIS Urban.
The user system requirements describe the requirements that must be met by your computer when using Urban. Ensure these requirements are met before starting to work with ArcGIS Urban.
Operating system requirements
Before installing ArcGIS Urban, ensure that you meet the minimum system requirements. See Install ArcGIS Urban to learn how to install Urban with ArcGIS Enterprise.
Operating system support
ArcGIS Urban on ArcGIS Enterprise is supported on Windows and Linux operating systems.
Urban is supported on the following Windows Server operating systems:
  • Windows Server 2025
  • Windows Server 2022
  • Windows Server 2019
ArcGIS Urban is not supported on Windows Server 2016.
Urban is supported on all Linux operating systems mentioned in ArcGIS Enterprise 12.2 system requirements.
Docker
In addition to a supported operating system, Docker is required to run ArcGIS Urban. For Docker installation instructions see Install Docker on Windows or Install Docker on Linux.
Hardware requirements
Each machine on which ArcGIS Urban is deployed requires 2 cores and 4 GB of disk space.
ArcGIS Urban is installed on the same nodes as the Portal for ArcGIS component.
User system requirements
For best results in ArcGIS Urban, verify that your browser and computer hardware meet the ArcGIS Urban requirements.
Currently, ArcGIS Urban is not supported on mobile devices.
Browser requirements
ArcGIS Urban requires a desktop web browser that supports WebGL (a web technology standard for rendering 3D graphics) and WebAssembly (a binary instruction format that in the case of Urban ports the Procedural Runtime [PRT] C++ code from ArcGIS CityEngine to run on the web). The latest versions of the most common desktop browsers have built-in WebGL support. To test whether your browser has WebGL enabled, go to get.webgl.org. To troubleshoot WebGL-related issues, see WebGL troubleshooting.
Keep your browser up to date, as WebGL and WebAssembly are evolving technologies and each browser version brings improvements that ArcGIS Urban uses for optimal performance. To use ArcGIS Urban, your browser must have hardware acceleration enabled.
ArcGIS Urban and other scene-based apps support the latest versions of the following web browsers:
  • Google Chrome
  • Microsoft Edge
  • Mozilla Firefox
  • Safari
Microsoft Internet Explorer is not supported.
Your desktop browser must have a minimum of 8 GB system memory and modern graphics hardware for 3D.
High-performance, stand-alone graphics cards typically have better performance than integrated graphics cards. To get more detailed information about WebGL2 requirements, visit the khronos.org WebGL wiki page.
Some systems can automatically switch between integrated graphics and dedicated graphics cards to render 3D graphics. ArcGIS Urban works best with a dedicated graphics card. In your graphics card driver settings, ensure that the per-application settings for your web browser are set to the dedicated graphics card. If this is not set, some point symbols and labels may not display correctly.
