Navigation and keyboard shortcuts
Urban offers different ways to interact with its 3D map view and its user interface:
Use mouse buttons for navigation
Use mouse buttons to navigate in the Urban map view, as listed below.
  • Left mouse button—Drag to pan around the view.
  • Right mouse button—Drag to tilt the view or rotate around the point you clicked.
  • Wheel button—Rotate the wheel to zoom in and out to preset zoom levels. Drag the wheel for continuous zoom.
  • Wheel button in combination with the Shift key—Press and hold the Shift key while using the wheel button to change the field of view of the camera.
Mouse buttons to navigate in
Use keyboard shortcuts for navigation
Use the following keyboard shortcuts to navigate in the Urban map view:
Keyboard shortcut
Zoom in.
Zoom out.
N
Set heading north.
P
Set the view perpendicular to the ground.
J
Move down, closer to the view.
U
Move up, away from the view.
W
Tilt the camera up.
S
Tilt the camera down.
A
Rotate the view counterclockwise.
D
Rotate the view clockwise.
B and drag
Rotate around from the current point of view.
Arrow keys
Move the view left, right, up, or down.
Keyboard accessibility
Use your keyboard to browse through the UI elements in Urban:
Key
Tab
Navigate forward through interactive elements.
Shift+Tab
Navigate backward through interactive elements.
Enter
Activate the current selection, for example, a button or a drop-down menu item.
Spacebar
  • Check and uncheck check boxes.
  • Expand accordions and drop-down menus.
  • Activate the current selection, for example a button or a drop-down menu item.
Arrow keys
Navigate through composite UI elements for example drop-down menu items or button options.
Escape
Close the current selection and return the focus to the last visited element.
General keyboard shortcuts
You can use the following general keyboard shortcuts in the plan editor and the project editor. To learn more about the plan editor, see Plan editor. To learn more about the project editor, see Project editor.
Keyboard shortcut
Ctrl+Z
Undo
Ctrl+Shift+Z
Redo
Keyboard shortcuts to edit geometries
You can use the following keyboard shortcuts when you add or edit geometries:
Keyboard shortcut
Click while pressing Shift
Select multiple parcels, spaces or existing metric values in the plan editor.
Right-click
Click a vertex to delete it.
Ctrl
Press and hold while editing to disable snapping.
Tab
Press to enter editing constraints.
