Work with the dashboard
The dashboard shows the metric values of your project scenario. Use metrics to quantify, analyze, and compare scenarios. As opposed to plans, metric values in projects are not calculated. You must input the values manually. Projects use the old metrics defined in the data manager; you cannot configure them per project. Projects don't support the new metrics and don't have existing metric values. If there are existing metric values in your urban model, they are not copied when you create a project.
Add and configure metrics
Projects use the old metrics defined in the urban model and don't support the new metrics. You cannot configure metrics in projects. See Configure the dashboard to learn how to configure metrics in the data manager.
Access the dashboard
Complete the following steps to access the dashboard, where you can visualize and analyze the metrics of a project scenario:
  1. Open the project editor.
  2. From the scenarios drop-down menu in the header, select a scenario.
  3. Click the Dashboard button at the upper corner of the view.
    There is a Configure metrics link in the side panel if there are no metrics defined in the urban model and you have privileges to edit it. See Configure the dashboard to learn how to configure metrics in the data manager.
    If the dashboard is empty, add metric values. See the Add metric values to a scenario section below to learn more.
    The dashboard side panel expands.
As opposed to plans, you cannot configure the project dashboard. Metric values are always represented as numbers. You cannot choose between different chart types or add icons. You cannot change the alphabetical order of the metrics in the dashboard. All metrics that have a metric value are visible in the dashboard.
You can add dashboard metric values for the old metrics configured in the urban model's data manager. Projects don't support the new metrics. See Configure the dashboard to learn how to configure metrics in the data manager. You must provide metric values manually, unlike when working with plans where the value is calculated based on building spaces and surfaces. Complete the following steps to add dashboard metric values to a scenario:
  4. Click the Edit dashboard button at the upper right of the dashboard side panel.
    The Edit dashboard side panel appears.
  5. Click the input field of a metric.
    The field is focused and highlighted with a blue border.
  6. Provide the metric value.
  7. Press Enter on your keyboard.
    Repeat steps 5 through 7 for every metric that requires a value.
  8. Click Return to dashboard .
    The metric values are saved. The dashboard side panel is displayed. All metrics with a metric value are visible in the dashboard side panel.
