Work with space-use types
A space-use type describes the usage of a space in a building. Space-use types are assigned to building spaces and surfaces and can be restricted by zoning or land-use types.
You can edit existing space-use types and propose new ones while editing a plan. Proposed space-use types are only available in the corresponding plan; they are not available across the entire city.
Add a space-use type
You can add a space-use type in the development mode
or in the plan configuration. Use the development mode option to add types one by one. Use the import options in the plan configuration to add multiple types from a hosted feature table or a spreadsheet.
Create a space-use type
You can create a space-use type in development mode
or in the plan configuration. Use the development mode option to add types one by one. Use the import options in the plan configuration to import multiple types from a hosted feature table or a spreadsheet.
Create a space-use type in development mode
To add a new space-use type in the development mode
, complete the following steps:
Open the plan editor.
Click Development
in the header.Ensure that the side panel is expanded.
To show or hide the panel, click the Expand button
in the upper corner of the view.Click Building and space use types
in the side panel header.The side panel shows two tabs. The Building types tab is open by default. It lists the building types for the plan.
Click the Space use types tab in the side panel.
The side panel lists the available space-use types for the plan.
Click the Add button
in the side panel header.The New space use type dialog box appears.
Provide a label and a description and populate the other space-use type parameter values.
Click OK.
The new space-use type is added to the Space use types tab in the side panel with a proposal flag next to its name.
Add space-use types in the plan configuration
To add new space-use types to the plan configuration, complete the following steps:
Expand the drop-down menu named after the plan and select Configure plan.
The plan configuration opens to the general plan settings tab by default.
Click Development and click Space use types.
Click Add and choose from the available options:
Single item—Add a single space-use type.
From spreadsheet—Import multiple types from a spreadsheet.
From feature table—Import multiple types from a hosted feature table.
See Manage space-use types to learn more about these options.
Click Return to plan
in the header when you finish adding types.
Add a space-use type based on an existing type
There are two places where you can add a space-use type based on an existing type: in the development mode
Add an existing space-use type in development mode
To add a new space-use type based on an existing type in the development mode
Click Development
Click the Configure button
of a space-use type.The Space use type dialog box appears that lists the parameters of the selected space-use type.
Scroll to the bottom of the dialog box.
Click the Create duplicate button
at the bottom of the dialog box.Provide a label for the duplicate space-use type and edit the other space-use type parameters according to your requirements.
Click OK.
The duplicate space-use type is added to the Space use types tab in the side panel with a proposal flag next to its name.
Add an existing space-use type in the plan configuration
To add a space-use type based on an existing type in the plan configuration, complete the following steps:
at the bottom of the dialog box.Provide a label for the duplicate space-use type and edit the other space-use type parameter values according to your requirements.
Click OK.
The duplicate space-use type is added to the table of space-use types.
Reorder space-use types
Reorder space-use types to change their position in the legend. To change the order of space-use types, complete the following steps:
Click Development and select Space use types.
The list of space-use types appears.
Drag the space-use types to reorder them.
Changing the order of the space-use types updates the last edited date of all space-use types.
Modify a space-use type
You can modify space-use types in the development mode
or in the plan configuration. To modify a space-use type from the list of types in the development mode, complete the following steps:
See the Add a space use type section above to learn how to get to the list of types.
next to the space-use type you want to modify.Modify the parameters.
Click OK.
The changes are applied to the space-use type.
Modifying a space-use type impacts existing spaces and surfaces of that type depending on the space-use type parameter you edited:
Label, Description, Color, Net area factor, and Metric parameters—The edits are applied automatically to building spaces and surfaces of that type.
Default floor height—The edits are not applied automatically to building spaces and surfaces of that type. Re-apply building types that contain the edited space-use type to parcels (see Assign building types) and re-assign the edited space-use type to building spaces or surfaces (see Draw and edit spaces) to make your changes effective.
Area per dwelling unit—The edits are not applied automatically if the space-use type is being used in a Dwelling units building type. Otherwise, the edits are applied automatically.
When modifying an existing space-use type, the changes are only applied to the current plan.
To view when the space-use type was last edited and who edited it, hover over the clock icon in the dialog box footer.
Analyze space use
To see a list of the total area per space-use type and each space-use type's share of the total new floor area in the scenario or in a subset of parcels, complete the following steps:
From the scenario switcher in the center of the header bar, select the scenario for which you want to see the space-use statistics.
Click Development
in the header.Choose from the following options:
Don't select parcels—The statistics are shown for all parcels inside the study area. If parcels are (partially) outside the study area, a warning label appears in the Space use in study area section of the side panel. Hover over the warning label to highlight those parcels.
Select a subset of parcels—The statistics are shown for the selected parcels.
Hover over the horizontal space-use types bar in the side panel and explore each space-use type's share of the total new floor area.
Click the space-use type in the list below the horizontal space-use types bar.
The view expands and shows more details about the corresponding space-use type: Name, New floor area (in scenario/in selection), and Parameters that are used to calculate metrics (see Work with the dashboard to learn more about metrics).
