Access and explore ArcGIS Velocity
Once you have installed and federated ArcGIS Velocity, you can access it at https://velocity.example.com:7143/arcgis/home by signing in as an administrator.
If you access Velocity through a reverse proxy, you can access it at https://reverseproxy.example.com/<context>/home and signing in as an administrator.
Administrators in the ArcGIS Enterprise portal can grant non-administrators access to Velocity by assigning specific privileges. For more information, refer to create roles and assign users.
The app launcher is also a location for organization members to open the web apps available to them. Members can access the app launcher from Apps in the Enterprise portal. Velocity must be registered as a custom app before it appears in the app launcher. For more information, refer to add Velocity to the ArcGIS Enterprise portal app launcher.
After you add Velocity to the app launcher, if it does not appear, clear your browser cache, then refresh the page.
Velocity app in the app launcher
Velocity app launcher
Refer to quick lessons to learn more about creating feeds and real-time analytics.
