Essential ArcGIS Velocity vocabulary
An understanding of the terms below is helpful when using ArcGIS Velocity.
Feed
A feed is a real-time stream of data coming into ArcGIS Velocity. Feeds typically connect to external sources of observational data such as Internet of Things (IoT) platforms, message brokers, or third-party APIs. Feeds parse incoming tabular, point, polyline, or polygon data and expose it for analysis and visualization. A feed is also a type of stream layer and can be added to a map to review new information as it is received. For details, refer to feed types and real-time data collection.
Real-time analytic
A real-time analytic performs processing on data collected through a feed and analyzes each individual message as it is received. Real-time analytics are used for transforming data, geofencing, and incident detection. Real-time analytics conclude with one or more outputs such as storing data in a feature layer or sending an email alert. For details, refer to real-time analysis.
Data store
Velocity can be configured to create and write to layers hosted in ArcGIS Data Store. ArcGIS Data Store supports two configurations relevant to Velocity: A relational data store that is part of your ArcGIS Enterprise base deployment and hosts standard feature layers, and a spatiotemporal big data store that is optimized for storage of high-velocity data. For details, refer to real-time workflow considerations.
Data source
A data source is an input in a real-time analytic that loads a set of stored information. This is often historical observations but can also be standard geographies or features that enrich observations with more attributes. Data sources load information from ArcGIS feature or map image layers or external cloud stores and can parse tabular, point, polyline, or polygon data. For details, refer to data sources and historical data ingestion.
Geofencing
Geofencing is a form of real-time spatial analysis in which features (often track points) are assessed using areas of interest (often polygon areas). Most commonly, point-based observations are analyzed to determine whether they have entered or exited a virtual perimeter. Geofencing examples also include understanding whether a storm is approaching or affecting an organization's facilities, whether an infrastructure pipeline intersects a flood warning area, or whether a fleet vehicle has deviated from its assigned route.
Geofencing can be performed in many Velocity real-time analytic tools to identify certain spatial relationships that may occur between features in a target feed and a set of join features (the geofences) in another feed or data source. The features used as geofences should be in a feed or data source connected to the join port of the tool. If the join features do not change, use a static data source for the best performance. For details, refer to geofencing analysis.
Dynamic geofencing
Several real-time analytic tools allow you to perform dynamic geofencing to identify certain spatial relationships that may occur between features in a target feed and a set of features in a join feed (the geofences), both of which are updating in real time or near real time. The tool performing the geofencing uses the most recent observation of any given track ID as geofences. For details, refer to geofencing analysis.
Output
An output is the final step in a real-time analytic that defines how results are handled. Outputs can take a variety of actions such as storing features to a feature layer, sending features to a stream layer, sending an email alert, or actuating IoT device behavior through a cloud platform such as Azure IoT Hub. For details, refer to outputs and fundamentals of analytic outputs.
Stream layer
Stream layers are feature layers with a stream service as their data source that provide access to a live data stream. Each stream layer corresponds to a specific geometric type: point, polyline, or polygon. Stream layers visualize new features on the map as soon as they are received because they subscribe to a WebSocket over which the data is flowing. For details, refer to stream layers.
Track ID
A track ID is a field in an incoming event or dataset that relates observations to specific entities. For example, a truck might be identified by its license plate number or an aircraft by an assigned flight number. These identifiers can be used to track the events associated with a particular real-world entity or set of incidents. A track ID is specified as part of a feed or data source schema. For details, refer to input data configuration.
Actuation
Actuation refers to the action of causing a machine or device to operate and is often the desired outcome of an IoT analysis process—for example, triggering air conditioning systems automatically when heat waves are expected or unlocking a security gate when an authorized vehicle is in proximity.In Velocity, outcomes from real-time analytics can be used to actuate devices or systems in external systems through outputs such as HTTP or sending messages to an output broker that can route commands to devices, such as Azure IoT Hub or Kafka.
For details, refer to fundamentals of analytic outputs.
