Fundamentals of analytic outputs
In ArcGIS Velocity, the real-time analytic processes or analyzes records. The results from these analytics can be handled in a variety of ways by disseminating data to one or more outputs.
An output is a required component in an analytic. Outputs perform different actions including storing features, sending features to a stream layer, issuing an alert or notification, or actuating IoT device behavior through a cloud provider IoT hub.
Choose an output format
When writing to certain output types, you can choose the desired format for output features. Options can include delimited text, JSON, Esri JSON, GeoJSON, shapefile, Parquet, or an Arcade expression. Below are the output types that allow you to choose the desired format for output features:
Delimited
JSON
Esri JSON
GeoJSON
Shapefile
Parquet
Arcade expression
Amazon SNS
verify
verify
verify
verify
Amazon SQS
verify
verify
verify
verify
Azure Event Hub
verify
verify
verify
verify
Azure IoT Hub
verify
verify
verify
verify
Kafka
verify
verify
verify
verify
RabbitMQ
verify
verify
verify
verify
Email
verify
Text Message
verify
HTTP
verify
Microsoft Teams
verify
Slack
verify
TCP (Client)
verify
verify
verify
verify
UDP (Client)
verify
verify
verify
verify
UDP (Server)
verify
verify
verify
verify
Write to Local File
verify
verify
verify
verify
Real-time analytics emit each message to output individually, as it is processed. This is because the real-time analytics process each individual message as it is received. For example, consider a Feature Layer (new) output configured in a real-time analytic. Each time an event is ingested, processed, and sent to the output, a new feature is either added or used to update an existing feature in the feature layer.
Implications of output rate and quantity
When emitting data from an analytic, it is important to consider the quantity and rate of data being sent to an output. Some output types are better suited to high velocity and high volumes of features than others based on their inherent function.
For example, a feed that is ingesting events at an average rate of 100 events per second and used in a real-time analytic to send email alerts may emit 100 emails every second. This could overload the capacity of your specified email server. The best practice is to use the Email output for incidents that are expected to occur infrequently.
