What's new in ArcGIS Velocity
The 12.2 release includes quality improvements, enhancements, and new functionality throughout ArcGIS Velocity. Highlights are provided below.
For details, refer to the What's new in ArcGIS Velocity ArcGIS Blog article.
General
General updates include the following:
Numerous accessibility enhancements were made.
Back-end libraries and dependencies were updated.
You can filter the list of feeds, data sources, and output types.
You can view a reference table with tags for each feed, source, and output type.
Partner feeds display partner icons and partner levels.
You can deploy Velocity behind a third-party reverse proxy using a configurable web context URL, which allows administrators to hide the port and customize the context. For example,
https://mysite.esri.com/velocity/homeinstead ofhttps://mysite.esri.com:7143/arcgis/home.The Velocity home app has moved to
/<context>/home, with feeds and real-time analytics at/<context>/home/feedsand/<context>/home/realtime, respectively.Administrators can configure an HTTP and HTTPS forward proxy that Velocity uses when feeds or outputs need to access external web services.
Velocity supports multi-site federation. A single portal in ArcGIS Enterprise can federate with more than one Velocity site at a time, allowing organizations to separate workloads across sites.
Administrators can monitor Velocity items and system health in ArcGIS Monitor, which provides a single place to track Velocity.
Administrators can edit the Backup Restore Location and Backup Frequency parameters in the backup restore settings.
Feeds and sources
The following are enhancements to feeds and sources in Velocity:
Velocity supports the following new feed types:
AeroDefense—Connects to the AeroDefense drone-detection API over a WebSocket (WSS) connection to receive real-time drone data.
AIS—Connects directly to a Transmission Control Protocol (TCP) source that streams Automatic Identification System (AIS) data for marine vehicle tracking.
UDP (Client)—Receives events sent to a User Datagram Protocol (UDP) server using a UDP socket connection.
TCP (Server)—Hosts a TCP socket that external clients connect to and send events over.
Added a new parameter, Get latest locations only, in the Geotab (LogRecord) feed. This parameter returns only the latest location for each device.
The minimum polling interval of the HTTP Poller feed is 5 seconds. Previously, it was 10 seconds.
Velocity feeds support geometry with M values or linear referencing measures from linear referencing system (LRS) sources. While configuring a feed, in the Identify key fields step, under the Location section, you can set the M (measure) parameter, which opens the Measuring section where you can specify the Route ID Field, Measure Field, To Route ID Field, and To Measure Field.
You can reload source data on a schedule without restarting the analytic.
You cannot delete a feature layer or map image service that a running feed uses. When you try to delete the item from your ArcGIS Online content, the Unable to delete item message appears. Previously, you could delete the item while the feed was running.
Outputs
The following are enhancements to outputs in Velocity:
Velocity supports the following new output types:
UDP (Server)—Sends event data to a UDP server using a UDP socket connection.
TCP (Server)—Hosts a TCP socket and sends events to connected clients.
XMPP—Sends plain-text messages to individual recipients or multi-user chat rooms through an Extensible Messaging and Presence Protocol (XMPP) server.
The following enhancements have been made to the Feature Layer (new) or Feature Layer (existing) outputs:
You can connect more than one pipeline when the schemas match or one is a subset of the other. Fields that a pipeline does not send are not overwritten.
Added a new parameter, Keep the newer feature for a Track ID based on Start Time. You can keep the newer feature for a track ID based on its start time instead of its arrival time. You set this in Advanced options on feature layer outputs.
Added a new parameter, Simplify feature geometry, to the feature layer outputs and the Stream Layer output. This parameter simplifies feature geometries to ensure they are written to the database correctly.
Analytics
The following are enhancements to analytics of Velocity:
Velocity supports the following new tools:
Calculate Fields by Regular Expression—Extracts, reformats, or validates text patterns in the incoming data.
Split by Attributes—Splits a string field into multiple rows based on a specified delimiter.
Out-of-the-box app launcher support is no longer available in the 12.2 release. To maintain access from the app launcher, configure Velocity as a custom app in your ArcGIS Enterprise organization.
You can add a new field to an existing Velocity-hosted feature layer directly from the Layers page without recreating the feature service.
Added a new parameter, Prevent wrong-way snapping on one-way roads, in the Snap to Network tool. This parameter specifies whether a point feature is snapped to a one-way road segment when it is traveling opposite to the road's permitted driving direction.
Updated the icon of the Multi-Merge tool in the user interface.
