Select Fields
The Select Fields tool selects a subset of fields to retain. This tool is useful when incoming data has extraneous or irrelevant fields. It can also be configured to remove geometry from features.
Example
The following is an example use case for the tool:
As a logistics manager, in analysis of point-based observational data, you used the Calculate Motion Statistics tool to calculate a variety of attributes about features in motion. You can then use the Select Fields tool to retain only the calculated attributes relevant to your requirements.
Usage notes
Keep the following in mind when working with the tool:
  • This tool does not require geometry. Geometry can be deleted using the Remove Geometry parameter. By default, geometry is retained.
  • You can remove fields when configuring a source or feed instead of using the Select Fields tool. Fields can also be deleted using the Map Fields tool.
Parameters
The following are the parameters for the tool:
Parameter
Data type
Input layer
The point, line, or polygon features to choose a subset of the fields to retain.
Features or tabular data
Fields to retain
One or more fields to be retained for the next step in the analytic model. Options include Select all, Select inverse, and Select none.
Field
Remove Geometry
Removes a geometry from the schema while preserving attributes and time data. The default is No.
Boolean
Consideration and limitation
Consider the following when working with the tool:
All fields and geometry can be deleted, but the output must have one field or geometry at a minimum.
