Azure Event Hub
The Azure Event Hub feed type receives event data from Azure Event Hub. Azure Event Hub is a managed service in Microsoft Azure that serves as a central message hub for bidirectional communication between ArcGIS Velocity and Internet of Things (IoT) devices.
Examples
The following are example use cases for the feed:
As a data analyst, you can use this feed to collect sensor data from Azure Event Hub.
A logistics company configures the Azure Event Hub feed to consume asset position and attribute information from their IoT sensors.
Usage notes
Note the following when working with the feed:
Get Azure Event Hub connection parameters from Microsoft Azure IoT Hub in the Azure portal.
After configuring feed connection parameters, configure input data to define the schema and the key parameters.
Parameters
The following are the parameters for the Azure Event Hub feed:
Parameter |
Description |
Data type |
Shared access key name |
The shared access key name for the Azure Event Hub credentials. |
String |
Shared access key |
The shared access key for the Azure Event Hub credentials. |
Password |
Event Hub endpoint |
The endpoint of the Azure Event Hub source, for example, |
String |
Event Hub entity path |
The path for the Azure Event Hub entity, for example, |
String |
