Cisco Edge Intelligence
The Cisco Edge Intelligence feed type in ArcGIS Velocity receives events from a Cisco Kinetic Edge and Fog Processing Module (EFM) when the Cisco system is exposing messages over the MQTT protocol.
Learn more about Cisco Kinetic EFM
Examples
The following are example use cases for the feed:
  • A data analyst wants to ingest sensor data from a Cisco Kinetic EFM broker.
  • A transportation agency configures a feed in Velocity to consume IoT sensor information collected by roadside gateways running the Cisco Kinetic EFM.
Usage notes
Keep the following in mind when working with the feed:
  • Cisco Kinetic EFM connection properties can be obtained from the Cisco Kinetic app.
  • After configuring feed connection properties, configure the input data to define the schema and the key properties.
Parameters
The following are the parameters for the feed:
Parameter
Data type
Host
The host name of the Kinetic EFM broker.
For SSL connections, use the prefix: ssl://.
For connections that are not SSL, use the prefix tcp://.
String
Port
The port of the Kinetic EFM broker.
Integer
Username (optional)
The username for the Basic authentication option.
String
Password (optional)
The password for the Basic authentication option.
Password
Client ID (optional)
The client ID that Velocity uses to connect to the Cisco broker.
Many brokers require a unique client ID for every connected client. It is recommended that you use a different client ID than specified in other feeds or apps.
String
Topic
Topics over which event messages stream. For example, kinetic_cars.
String
Quality of Service Level
Specifies the quality of service (QoS) level, which defines the delivery guarantee for a specific message.
  • 0—At most once. The message is sent once, and the client and broker take no additional steps to acknowledge delivery of the message (fire and forget).
  • 1—At least once. The sender retries sending the message multiple times until acknowledgement is received (acknowledged delivery).
  • 2—Exactly once. The sender and receiver perform a two-level handshake to ensure the receipt of only one copy of the message (assured delivery).
Integer
Consideration and limitation
Consider the following when using the feed:
The Cisco Kinetic EFM host must be externally accessible on the internet.
