Dataminr First Alert
The Dataminr First Alert feed type in ArcGIS Velocity creates a built-in HTTP endpoint that receives real-time alert events from Dataminr First Alert. Dataminr First Alert provides AI-powered real-time event, threat, and risk intelligence for public sector organizations.
Learn more about the Dataminr-Esri alliance
Examples
The following are example use cases for the feed:
  • An emergency management agency wants to receive real-time alerts about natural disasters, severe weather, and public safety incidents. They collect Dataminr First Alert data into Velocity to maintain situational awareness during active events and coordinate response efforts.
  • A public safety organization wants to monitor threats and incidents in their jurisdiction. They use Dataminr First Alert data to track real-time events and correlate alerts with geographic areas of responsibility.
  • A disaster response team wants to aggregate real-time incident intelligence during an active event. They store Dataminr First Alert data and run analytics to identify emerging hotspots and allocate resources effectively.
Usage notes
Note the following when working with the feed:
  • The feed is a receiver type that creates an HTTP endpoint. After the feed is created, the HTTP endpoint URL is available on the feed's details page. Provide the HTTP endpoint URL, username, and password set during feed configuration to Dataminr to begin receiving data in the feed.
  • Key fields are pre-configured for the feed. The alertId field is set as the Track ID and the alertTimestamp field is set as the Start Time.
  • Velocity automatically constructs point geometry from the estimatedEventLocation_lat and estimatedEventLocation_lng fields.
  • The date and time information is stored in the alertTimestamp field.
  • The feed automatically flattens JSON data received from Dataminr. Nested objects are represented as underscore-delimited field names. For example, metadata_cyber_vulnerabilities.
  • Additional fields are provided as arrays within string fields. These can be further processed in real-time analytics using the Calculate Fields or Map Fields tools.
  • The feed supports removing unwanted fields and adjusting field names. You cannot change data types or add new fields because the alert schema required by Dataminr cannot be modified.
Parameters
The following are the parameters for the feed:
Parameter
Data type
User Name
The username secures the HTTP endpoint for this feed. Register this value in the Dataminr system.
String
Password
The password secures the HTTP endpoint for this feed. Register this value in the Dataminr system.
String
Additional logging
(optional)
Specifies whether logging is turned on for raw requests and responses issued by Velocity to Dataminr.
Only turn on the Enable Request Logging option for troubleshooting and turn it off when troubleshooting is complete. After turning on the option, start the feed; the debug-level logs are available on the feed logs page. Contact Esri Technical Support for help with troubleshooting, if necessary.
Boolean
Consideration and limitation
Consider the following when using this feed:
Dataminr Customer Support uses the username, password, and HTTP endpoint URL to push data to this feed. If the username or password is unavailable, create new credentials and provide them to Dataminr Customer Support.
