Feature Layer (archive)
The Feature Layer (archive) source type in ArcGIS Velocity loads features that have been exported to a feature layer archive.
Examples
The following are example use cases for the data source:
Another user selects a feature layer that has a data retention export strategy enabled to ingest historical data for analysis.
A city planning department selects a feature layer with a data retention export strategy to analyze five years of historical traffic data. This helps them identify congestion patterns and make data-driven decisions to improve road infrastructure.
Usage notes
Keep the following in mind when working with the data source:
When choosing a feature layer that has an associated feature layer archive, you can filter the available content while browsing for your content or your organization's content. You can further filter by the following:
Content modified on a specific date
Content created on a specific date
Content with specific tags
A feature layer archive only includes features that have been exported and deleted from the associated active feature layer. In real-time analytics, the feature layer archive can be brought in as a source.
When data is exported to the feature layer archive, additional date fields
START_TIMEandEND_TIMEof the feature are created. The values are a duplicate of the date and time values in the original fields and can be dropped if necessary.After configuring source connection properties, configure input data to define the schema and the key properties.
Parameter
Parameter |
Explanation |
Data type |
Item ID |
The item ID of a feature layer that has an associated archive. |
String |
