Feature Layer
The Feature Layer feed type in ArcGIS Velocity polls for features at a fixed schedule.
Examples
The following are example use cases for the feed:
  • A user configures a feed referencing an ArcGIS Server hosted feature layer to load features added by users.
  • A GIS analyst provides the URL to an ArcGIS Server feature layer (such as https://sampleserver6.arcgisonline.com/arcgis/rest/services/Wildfire/FeatureServer/2) containing the desired features to load every minute, for use in a real-time analytic.
Usage notes
Keep the following in mind when working with the feed:
  • The feed polls the feature layer to load features at the rate defined on the Feed Polling Interval step of the feed configuration wizard.
    • The timestamp field specifies the date field for getting the latest features. You can define the timestamp field value in the timestamp field step. If you do not specify a timestamp field value, at every interval, the feature layer feed loads all features from the feature layer as events for processing.
    • If a timestamp field value is specified, the first time Velocity polls the feature layer, it loads all features with the datetime timestamp field within the past minute and earlier than the first feed poll time that also meet the criteria of the WHERE clause. Each subsequent poll, it loads only features with a timestamp field value between the last polling time and the current polling time that also meet the criteria of the WHERE clause.
    • Velocity requires timestamp values to be stored in Coordinated Universal Time (UTC). If a timestamp value is specified but the values are not stored in UTC, polling the feature layer may return unexpected data.
  • When browsing to choose a feature layer item, you can filter by folders, favorites, groups, or organization. You can then further filter by date modified, date created, and tags.
  • ArcGIS Server feature layers can also be loaded using a URL. This must be an ArcGIS Server services directory REST URL (such as https://sampleserver6.arcgisonline.com/arcgis/rest/services/Wildfire/FeatureServer/2). This URL must end in /FeatureServer/# or /MapServer/#, where # is the layer number.
  • To load a secured feature layer from a URL, you must first add a service or document from a URL to ArcGIS Online and choose to store credentials. You can then browse to the registered ArcGIS Online item to select the secured feature layer.
  • When a polling frequency is set, the polling occurs at regular clock intervals as opposed to the start time of the feed. For example, if a feed is set to poll for data every 5 minutes and started at 8:03 a.m., the first request for data occurs at 8:05 a.m., the next at 8:10 a.m., and so on.
  • Use caution when defining the feed polling interval. You must ensure that the feature layer you are polling can return responses within the specified polling interval. It is recommended that you test the response time of a query request to this feature layer, using the same query that you apply in the feed configuration. Never set the polling interval to a shorter interval than the typical response time of your feature layer query. For more information on scheduling feed polling intervals, refer to feed polling interval scheduling.
  • After configuring the feature layer connection parameters, configure input data to define the schema and the key parameters.
  • For optimal polling performance, if available it is recommended to create an attribute (field) index on the Date field for latest features option referenced by the Timestamp field parameter. This improves query efficiency when filtering records between polling intervals. Attribute (field) indexes can only be created on feature layers that are owned or administered by the Velocity user.
Parameters
The following are the parameters for the feed:
Parameter
Explanation
Data type
WHERE clause
The WHERE clause parameter specifies a Structured Query Language (SQL) clause used to filter features loaded from the specified feature layer. The default is to load all features using 1=1. This default WHERE clause can be modified to include specific attribute values and logic conditions.
SQL-92 where clause syntax on the fields in the layer is supported for most feature layers.
Hosted feature services generated in Enterprise running on a spatiotemporal data source have restrictions on what is supported; they only support a subset of SQL-92.
The following is a list of supported SQL-92 with such feature layers:
  • ( '<=' | '>=' | '<' | '>' | '=' | '!=' | '<>' | LIKE )
  • (AND | OR)
  • (IS | IS_NOT)
  • (IN | NOT_IN) ( '(' ( expr ( ',' expr )* )? ')' )
  • COLUMN_NAME BETWEEN LITERAL_VALUE AND LITERAL_VALUE
You can update this parameter in the filter data step.
QueryString
Out fields
The Out fields parameter specifies the fields to load from the feature layer into Velocity.
The default is an asterisk (*), which loads all fields.
If specific fields are provided, they must be listed as comma-separated field names, for example:
device_id,timestamp,horizontal_accuracy,latitude,longitude
String
Output spatial reference (optional)
The Output spatial reference parameter specifies the well-known ID (WKID) of a spatial reference. The default WKID is 4326.
Velocity loads data from the feature layer in the spatial reference set in this parameter.
String
Additional logging
(Optional)
Specifies whether Velocity turns on logging for raw requests. The default is False.
Turn this parameter on only for troubleshooting, then turn it off when complete. Once turned on, start the feed; the debug level logs are available on the feed logs page. Contact Esri Technical Support for help with troubleshooting, if necessary.
Boolean
Timestamp field
Specifies a date field for retrieving only the latest features.
If you do not specify a timestamp field value, at every interval, the feed loads all features from the feature layer as events for processing.
If a timestamp field value is specified, the first time Velocity polls the feature layer, it loads all features with the datetime timestamp field within the past minute and earlier than the first feed poll time that also meets the criteria of the WHERE clause. Each subsequent poll, only features with a timestamp field value between the last polling time and the current polling time that meet the WHERE clause criteria are loaded.
String
Considerations and limitations
Consider the following when using the feed:
  • The feature layer must be accessible over the internet.
  • Do not set the polling interval to a shorter interval than the typical response time of your feature layer query.
  • Velocity does not support layers that require credits for data queries.
  • If the user credentials are invalid, the feed retries the connection up to three times. Invalid credentials errors appear in the logs. The feed automatically attempts to restart after a delay, based on the configured recurrence schedule.
