Stream Layer
Features in a Stream Layer feed originate from a stream layer in an ArcGIS organization.
Examples
The following are example use cases for the feed:
Configure a feed referencing a stream layer output from an ArcGIS Velocity real-time analytic.
Add a publicly accessible stream service published from ArcGIS GeoEvent Server to ArcGIS Online as a stream layer item and configure a feed referencing that stream layer.
Usage notes
Keep the following in mind when working with the feed:
The feed subscribes to a stream layer's stream service to receive features as they are broadcasted by the stream service.
When choosing a stream layer item, filter by your folders, favorites, groups, organization, or for all features from ArcGIS Online. You can further filter by the date modified, date created, and tags.
Learn more about defining the schema and key fields to configure input data
Parameters
The following are the parameters for the feed:
Parameter |
Description |
Data type |
WHERE clause (optional) |
A Structured Query Language (SQL) Supported operations for stream layers include the following:
String |
Out fields (optional) |
A comma-separated list of fields from the stream layer that will be loaded into Velocity. If no fields are specified, all fields will be loaded. The following is an example:
String |
Output spatial reference (optional) |
Specifies the well-known ID (WKID) of a spatial reference. Velocity loads data from the stream layer in the spatial reference defined by this parameter, for example, |
String |
Extent (optional) |
Specifies the extent filter for incoming data broadcast by the stream service. This parameter is important if there is a large amount of data outside an area of interest you do not want to process. The geometry must be the Esri JSON Envelope geometry type. The following is an example:
String |
Consideration and limitation
If the stream layer references an ArcGIS Online stream service, the service must be unsecured.
