Vectronic Aerospace
The Vectronic Aerospace feed type in ArcGIS Velocity creates a built-in HTTP endpoint to receive global positioning system (GPS) data from Vectronic Aerospace wildlife tracking collars. The data transmitted from these collars can be used for wildlife monitoring and real-time movement analysis.
Examples
The following are example use cases for the feed:
A wildlife biologist uses data from wildlife tracking collars to analyze wildlife migration patterns.
A department of transportation uses data from wildlife tracking collars to update dynamic message signs (DMS) to remind motorists to stay alert and slow down when animals are in the area.
Stakeholders use insights from wildlife tracking collars to inform planning for secure and sustainable wildlife corridors.
Usage notes
Keep the following in mind when working with the feed:
This feed is designed to receive data directly from Vectronic Aerospace only.
The feed supports configuring key fields, removing unwanted fields, and adjusting field names. All Vectronic Aerospace fields are visible when defining the schema, regardless of the values selected for the Data Event Types parameter. Adding new fields is not supported, as the schema is predetermined based on the data provided by Vectronic Aerospace.
After setting the Data Event Types parameter, adjust the schema and define the key fields by configuring input data. When using the
sctsoracquisitionTimefield to configure the Date and Time parameter on the Identify Key Fields page, choose the Other (string) in the Date format option and type yyyy-MM-dd'T'HH:mm:ssZ in the Date Formatting String option.After creating this feed type, access the feed’s Item Details page and copy the Rest Endpoint Path receiver URL available under the Feed details section. This URL must be entered into your Inventa account preferences to start receiving data from Vectronic Aerospace.
Parameter
The Vectronic Aerospace feed parameter is described below:
Parameter |
Description |
Data type |
Data Event Types |
The Data Event Types parameter filters data received from Vectronic Aerospace using the
Learn more about data event types in the Vectronic Aerospace documentation |
String |
