Verizon Connect Reveal
The Verizon Connect Reveal feed type in ArcGIS Velocity creates a built-in HTTP endpoint that can be used to receive GPS Push Service messages from Verizon Connect Reveal.
Learn more about Verizon Connect Reveal
Examples
The following are example use cases for the feed:
  • A utility company wants to track their fleet vehicles. They use real-time vehicle location information to send alerts when vehicles approach job sites with hazardous conditions.
  • A delivery company wants to track their fleet vehicles. They use real-time vehicle location information to understand driver habits and send real-time notifications to reduce vehicle idling.
Usage notes
Keep the following in mind when working with the feed:
  • Start the feed in Velocity before performing the initial subscribe step in Verizon Connect Reveal, since the feed must already be running to receive and confirm the subscription request.
  • When a feed is started for the first time in Velocity, you must review the feed logs in another browser tab to confirm the subscription by browsing to the Subscribe URL value included in the feed log message. This requirement ensures that the subscription is valid.
  • The feed processes only events with the GPS Push Service schema defined by Verizon.
  • The feed supports configuring key fields, removing unwanted fields, and adjusting field names. Changing data types or adding new fields is not supported because the GPS Push Service schema required by Verizon cannot be modified.
  • After you create the feed, the URL in the HTTP Endpoint Path parameter is available on the feed details page. Use this URL for data that is pushed from Verizon Connect Reveal.
  • After configuring feed connection parameters, define the schema and the key parameters by configuring the input data.
  • The datetime information is stored in the updateUTC field as a string. When configuring the feed, on the Identify Key Fields page, set the updateUTC field to Start Time, with a date format of Other (string) and a date formatting string of yyyy-MM-dd'T'HH:mm:ss'Z'.
Parameters
The following table describes the parameters for the feed:
Parameter
Data type
HTTP Endpoint Path
The full URL that Verizon Connect Reveal uses to send GPS Push Service messages.
Velocity generates and populates this parameter after you publish the feed.
String
Username
The username used to secure the HTTP endpoint created by the feed.
String
Password
The password used to secure the HTTP endpoint created by the feed.
String
Schema Version
Specifies the fixed schema used by the feed. Version 2 uses Float64 for fields that support fractional values; Version 1 does not.
Options are as follows:
  • Version 1 (supports integer values)
  • Version 2 (supports Float64 for fractional values)
The default is Version 2 (supports Float64 for fractional values).
String
Consideration and limitation
Consider the following when using the feed:
Verizon Customer Support uses the username and password, along with the HTTP endpoint URL, to push data to the feed. If the username or password is not available, you must create new credentials and provide them to Verizon Customer Support.
